Did you put the clear cmos jumper back on correctly? I'm only 33 but i sometimes have an issue getting jumpers on correctly, despite the fact i can see them pretty well.
Use a flat head screwdriver to start the system up also, take the case wiring out of the loop(just something else to rule out)..
If it were me, i'd be inclined to remove the hardware from the case, find something to sit the motherboard on and attempt to boot with the absolute bare minimum, ie. CPU, 1 stick of ram and onboard GPU(should be active after clearing CMOS). I'd also use the paperclip trick on the PSU to confirm that powers on correctly, with any connectors removed from the motherboard(i'd have suggested disconnecting them reconnecting each anyway in testing).
