- 16 Mar 2013
Hi guys,
I'm turning to you guys for some ideas.
My set up is as follows:
ASUS Crosshair V,
AMD FX6350 @ 4500mhz and 1.5v w/ XSPC water block.
2 x EVGA GTX780 in SLI, 1 w/ XSPC block and 1 w/ EK block.
Corsair 990D case
1 x 480mm roof rad with 4 Corsair fans pulling air through the roof, pushing through the rad
1 x 360mm basement mounted rad with 3 Corsair fans pulling through the side panel and pushing through the rad.
3 x front panel fans pulling air into the case
1 x massive exhaust fan pushing air out the back of the case.
These issues have really become apparent since yesterday when I added the second GTX780 which was second hand and came with an EK water block.
My CPU temps are fine, my GPU temps are through the roof though. I run a triple monitor set up, which I feel is important to share. I have tried various monitor configurations and SLI/physX configurations with no joy.
What I'm seeing is this:
CPU temps are fine, all fine and dandy.
GPU 2 which has two monitors on DVi idles at 30 Celsius.
GPU 1 which has one monitor on HDMI idles at 60 Celsius.
Load a game, we get to 100 Celsius in no time and it all crashes. I have throttled the GPUs to stay at no more than 95 Celsius which is insane as they clock out at 300mhz.
I've tried running the cards with all monitors on one card and physx on another, auto assign physx, disable SLi, tried all monitors on each card, tried splitting monitors and disabling SLI etc etc. You get the point.
I thought that I was just running out of resources in games but I think that it was temp throttling all along and now with 2 cards, it's got worse.
The EK cooled card has a backplate and to touch, the card is red hot. The backplate and cooling plate. Fitting is cool. The XSPC card and block are cool all over. Water doesn't feel particularly hot.
I've ordered up another XSPC block and SLI bridge as at the moment, I can't locate the cards in the right place so will strip both and redo thermal paste.
But, in the meantime, any ideas or thoughts on how bad it is would be appreciated.
I have an option of taking the kit out of an unused rig and run a second DC5 powered loop with a 360mm rad to cool the CPU and GPU independent of one another. Advice on the best twin loop set up based on my available equipment would be great.
Thanks all, I know it's been a long one.
ASUS Crosshair V,
Corsair 990D case
