- 2 Dec 2003
- Inverness Scotland
Hi guys,
Really need some help here. My PC has been dying over the past hour or so, and I'm not sure what the problem is.
Everything was fine yesterday, and today I come home from work looking forward to starting a new character on Oblivion.
First I downloaded the new drivers from Nvidia because I heard they have a few Oblivion optimizations. Uninstall old ones, driver cleaner, restart and install the new ones. Everything is fine
I decide to do some cleaning up, so I put on the Nvidia Mad Mod Mike Demo while I work. I go out of the room and come back to find the monitor has lost signal. Tried re starting, POST completes BEEP but monitor loses signal again.
This carries on for some time, and I also notice the fans sound different as well, the speeds arent constant. Speeding up and slowing down.
I noticed if I leave it alone, the PC keeps re starting. Passes POST and then monitor loses signal.....
Opened the case, replaced my 7800GT with an old PCI card that I KNOW works, but no signal output at all from that one.
Tried different RAM, but no luck
Sometimes I try to power up but NOTHING comes on appart from the LED's on the front of my coolermaster case......no Fans, nothing
I suspect my PSU may have gone - Globalwin 460 Watt Saphire model....but I need to confirm before I buy another one.
Thanks folks, really need advice here. At the moment the PC either POSTS and monitor loses signal, or doesn't power up at all
