hi everyone,
ok .. ill list the specs and symptoms best i can to make things easyer:
q6600 stock
corsair h50 cooling.
2x2gb corsair dominator something something 1066 stuff
Asus p5n32e-Sli
8800gts 320mb
antec 550w psu
2x500gb samsung spinpoints
ok now the symptoms..
at first i thought there was a hard drive fault .. as the system seemed to hang ... but its more a case of windows taking ages to load up ( while still being active) and then when i try to open anything or right click.. it seems to pause for up to 5 mins then do it ... simply put it felt like anything in ram was running at full speed but anything accessing the hdd responded very slow.
but when i transfered some data from the disk after thinking it went at full speed.
so i checked the disk ... a lot ... windows full check , then samsungs own hard disk check thing .. full surface scan .. comes up with nothing .. so i reinstall.
things seem fine until i boot it up just now and i get bios error checksum something ..
i turn off .. i turn back on (it never gets old as a problem fixer) the system boots but with bios defaults .. so i let it , and after the "safe mode or not" screen windows loads...
things seem fine until it slows down .. a lot .. then hangs.. then blue screens , page fault in non page area..
now it wont boot into windows.
im starting to think maybe its the motherboard, its cooled very well with the h50 .. which i cant advertise enough ..
my question is ... withought geting a whole other pc (which i dont have access to ) to fault find ... is there any other way to make sure its just the mobo so i can take it out ... stomp on it in a rage and put in a new one?
so .. please ideas thoughts tests ... i need to get this thing back working...
I can stretch to get a new mobo .. but if it can be avoided it would be better
righty.. over to u , thanks in advance for any help btw
q6600 stock
Asus p5n32e-Sli
8800gts 320mb
antec 550w psu
