- 28 Nov 2005
IRQL_NOT_LESS_OR_EQUAL
Technical Information
STOP 0X0000000A (0XA9E53498, 0X00000002. 0X000000000, 0X80420380)
What is that all about. Its got a blue screen behind it.
I posted a hdd issue in the hdd section before, but no one had any suggestions really..
anyways, i sorted that, i managed to get my hdd formatted (after puttin a 120gb ide slave in and the whole system went kaput, froze just before the first window screen on my main hdd and on the slave it only ever said system disk error)
but i managed to get my main hdd formatted and was installing windows xp on my relatively new pc but it only ever got to "installing devices" bit of the windows installation then it either froze... or that message appeared with the blue screen (top of this post)
im pretty baffled... ive reset the bios and everything. the setup is pure innovation mobo, amd 64 3500 cpu, x1800xt gfx (just bought), 2gb gzkill memory, 580w hiper type r.
all i get on that comptuer now is that stupid message that ive put at the top of this post... any help would be really helpful as i seriously need the comptuer working ASAP. plus ive spend loads of money buying the dam thing.
putting a 120gb slave drive in started all this trouble in the first place.. thats the only thing i changed about the system
