Major problems, please help!!!
18 Jan 2006
Norwich
Motherboard Repairs- Need to solder back on battery holder!
Hiya,
I've got what is almost certainly going to turn out to be a broken board here, but please help anyway :p
Anyway, for those who have seen my GH thread ( http://forums.overclockers.co.uk/showthread.php?t=17596870 ) I have serious problems getting the board in question (Abit KX7-333R) to boot. These problems have taken a pretty major twist- After trying known good RAM still nothing, so I decided to try changing the CMOS battery, again for a known good. Trouble is, the whole batery socket came off the board when I pinged the battery out (Yes, I have changed CMOS batterys in the past ;) )
Now the board is actually booting, but I've got GRUB error 21 instead (Drive setup toasted in the BIOS). Any thoughts on a bodge-fix- I can't keep the battery socket on properly just by fitting it back in place, but if I push at the right angle I can get the standard checksum fail & defaults loaded as opposed to the CPU setup wrong message without the battery installed.
Soldering wise, I may be able to do something but I suspect my iron tip is going to be too big.
Also, does the behaviour in the previous thread point to a wider hardware problem?
-Leezer-
I don't know much about this kind of thing but maybe it would be easier to stick it with some conductive paint rather than clumsy soldering, especially onto tiny mobo tracks??
Its only two pins as such that go into tracks- Nothing much there really (bottom right mobo corner).
As I see it, I'm probably going to have to solder wires to the two pins and then remount the battery holder elsewhere. I would still like thoughts of anyone who's come across this sort of problem though- There must definitely have been something underlying; Battery holders don't just come off :eek:
Bump ;)
Picked up a 1mm bit for the iron & a new battery today, would appreciate thoughts from anyone who's done this type of job before.
-Leezer-
Well, you could try something like attaching small wires to the motherboard tracks and solder the wires to the battery. No idea if that would work though :/
Fortunately the socket assembly's still intact, so I'm planning to mount the battery in that somwhere near the bottom of the case & play from there. Its more the soldering I'm worried about than anything else- Never tried anything quite so fiddly & so many possibilities for going wrong :eek:
Least its only a cheap Socket A board!
-Leezer-
