Major problems R9 290x and a 4k samsung TV
15 Nov 2014
I am trying to run a radeon R9 290X on a Samsung 6 series 4k TV. I am running the latest crimson drivers and windows 10 64bit. When the resolution is set to 4k resolution the edges of the desktop are out of view on the TV screen. Furthermore, the AMD crimson drivers don't have any "Scaling options" anymore which they used to have on the AMD catalyst drivers.
I used to be able to use this feature to simply scale the display size down a little to fix the issue. Also windows 10 is only detecting the Samsung 6 series 4k TV as a "Generic Pnp Monitor" I kid you not!
Does anybody have any solutions to this because I am stuck with a 4k TV and I can only run windows 10 at 1920x1080 because if I run at 4k resolution the some of the display is missing and I can't scale it in the crimson software.
OP
15 Nov 2014
It's under/overscan
Im pretty sure it in the crimson drivers (dunno about latest relive set). Temporarily had to use hdmi and recall having to change it back to normal. It was a few months back though. Im away from the desktop to check.
Thanks for your answer. I have just read online that if the resolution in Windows is set to 4k resolution then AMD software doesn't allow overscan/underscan scaling. Nvidia does. This is very poor by AMD and they should do better. I have had a look through the samsung TV settings and I can't immediately see any scaling options. It's a Samsung UE50KU6000. I am quite frankly astonished that I am struggling to find in December 2016 a feature that 1980's portable TVs used to have, a simple scaling feature
OP
15 Nov 2014
so are the drivers stuck in overscan with no way to change that or has overscan been disabled completely and you need to adjust your tv?
There is no overscan option at all in the settings when the resolution is set to 4k and a part of the screen is missing (For example I cant see the windows 10 start button. As soon as I reduce resolution to 1920x1080 the screen becomes fully viewable,
