Hi I seem to be having a problem with my internet speeds; I live around 380M from the exchange and have 02 ADSL2+ Service where for around 9 months I have had around near enough the full 24Mbps.
For the past two weeks I have been having very slow speeds, here are the stats;
Uptime :
0 days 18 hours 24 mins 33 secs
Type :
ADSL2+ Annex A
Line Rate (Up / Down) :
104 Kbps / 2472 Kbps
Noise Margin (Up / Down) :
7.8 dB / 8.6 dB
Attenuation (Up / Down) :
63.7 dB / 69.5 dB
Power (Up / Down) :
As you can see that is very poor!!! My Attenuation is usually 16 or there abouts, why has it jumped so high? Have they moved the exchange??!!!
I have no idea what the heck is going on and so don’t 02 I have tried all sorts, checking the wires in the master box unplugging every extension cable and having it direct into the master test switch.
BT Were doing updates on the Exchange to make it Fibre. I can only hope this has caused it? I think 02 are sending a BT engineer down to have a look!
Uptime :
Type :
ADSL2+ Annex A
7.8 dB / 8.6 dB
63.7 dB / 69.5 dB
Power (Up / Down) :
I have no idea what the heck is going on and so don’t 02 I have tried all sorts, checking the wires in the master box unplugging every extension cable and having it direct into the master test switch.BT Were doing updates on the Exchange to make it Fibre. I can only hope this has caused it? I think 02 are sending a BT engineer down to have a look!
