major upgrade - help required!!!
22 Jan 2008
OK, after two failed attempts I managed to install vista 64 onto a raid-0 set. then spurious system hangs and one more HDD corruption....started all over again....
Spec is Vista 64, 2xMaxtor 180gb in raid0, Asus M3A32-MVP, phenom 9600, ATI sapphire HD3870. (spider platform so should all be compatible). 4 x corsair 1gb-ddr2-800, enermax liberty 620Wpsu
I got almost eveything working, then went for the ATI drivers - now the damned thing will start to load windows and crash 10 seconds into the green bar running at the bottom. Tried popping my old AMD 64FX2 CPU in, same thing. The last thing to try is the PSU - is it likely to be this causing all these problems????.
