- 8 May 2011
- London
Hi, I've got an Asus P8Z68-V Pro, and all my fans are controlled via a fan controller. The problem with this is that even if you tell it too, it refuses to ignore that there is no CPU fan, and so booting up takes an extra 10 or so seconds, and makes the beep code that gets annoying after a while. So basically, is there a way of making it think there's a fan attached without actually attaching one?
