make a usb wired printer wireless?
12 Feb 2006
Surrey
i don't have a place for my printer to be close to my desktop. at the moment i store my printer the other side of the room in a cupboard but it's annoying each time I use it to have to move it, plug it in, use it and then put it back.
Is there any way to have a wireless usb attachment that makes the printer appear wired while being wireless and then just powered on the other side of the room?
Plug it into your router?
I think there are a few options to look at. What connections does your printer have? Or what model printer is it? I don't know anything about google nest / wifi / router. What ports / connections does it have?
Depending on the model of printer you might be able to connect a usb wifi dongle to it (either made by the printer manufacturer or a random third party device that supports the printer) instead of connecting it by usb directly to the computer. I think hornetstinger was saying that if you connect the printer by USB to your router the router would then present the printer to any network connected devices. There are also USB to ethernet adaptors that might work if you have any spare ethernet ports either on the router or on the PC / laptop.
If you let us know what connections are available on your printer and what are available on your network there might be some ideas as to how the two could be connected. You also might be able to just get a much longer USB cable?
Cheers.
