Make FSX fly
7 Dec 2008
Hi all,
Firstly I have a : -
ASRock Conroe 1333-d667
Dual core intel Pentium D 925 3000 mhz
2 gig ddr2-667 SDRAM
and a 4830 ati graphics card
FSX and my computer in genreal is running slow - its starts out ok and then just slowley grinds to a halt!
What can I do to quicken things up - can I just upgrade the RAM would that make a big difference or is it a CPU job!
p.s I am running Vista 32bit
many thanks guys!
FSX likes fast CPUs it's not so fussy about GPU power. An overclocked i5 would see a massive improvement. If you aren't up for replacing the motherboard, you could look at which quad cores your board might take (and whether you'll be able to successfully overclock).
Id look at trying to OC what your currently have a little first. You might get it safe @ 3.4ghz and could see the frame improvements needed to play it without jitter.
If your looking to change things a little , see if you can pick up a Q6600 second hand for around £90. Should pop right in your existing build. Add another 2GB memory and your laughing ready to go.
McT
Hi all,
many thanks guys!
RAM would be wasted as the rest of the system would be letting you down.
I'd think about replacing the CPU: you can stick in any Core 2 Duo CPU based on the Conroe chip, but you cannot stick a quad core CPU into it.
Look for used E6600s (seem pretty common at the moment): you won't get access to MM for another 225-odd posts, so look on other websites for used action.
Would one of these help?
Intel Core™2 Duo E6600, 2.4 GHz E6600 OEM PROCESSOR
Will that be much better for FSX?
Not unless you overclock it I wouldn't have thought. It will be faster at stock (2.4GHz) than your dual core pentium at 3GHz, but I wouldn't have thought it would be night and day.
alright i is getting the picture i am screwed! So what do i need to do to improve things! I can spend about 100 o 200! ill need a new motherboard and CPU? What do you guys recommend?
