I've been researching for quite a while now and have decided to try and make a final decision once and for all.
I will be using the monitor for PS3 gaming alone. Not a hardcore gamer, just want a great visual experience when I do play.
The monitors I have narrowed it down to are:
Benq M2700HD
Has been on my list pretty much the whole time. Seems to have good specs and what reviews I have found are positive.
Iiyama ProLite B2712HDS
Have seen many threads end up with the suggestion of choosing this monitor, and so have heard very good things said about it.
Hanns.G HZ281HPB
Been reading through the large thread all about this monitor, with everyone saying it's pretty much perfect!
My doubts with it are that, if I'm understanding correctly, as it is a 16:10 monitor as opposed to a 16:9, the picture from my PS3 will be stretched to fit the screen (apparently no way to have the black bars above/below
). So this may count this monitor out, which would be unfortunate as this is the one I have heard the greatest feedback on
(Extra Question: If the monitor is a 1920 x 1200, then does that mean that as the PS3 can only produce at 1920 x 1080, that the image will be downscaled and result in it looking worse than on a 1920 x 1080 monitor?)
ViewSonic VX2739WM
Seen it mentioned a fair few times around these forums and seems to have the highest specs out of the lot.
Asus VE276Q
Have not done much research into this but was rated as the best 27" monitor for gaming on a site so I thought I should consider it.
So these are the 5 that I have come down to. If you know of another that I should seriously consider over these then I would both love to know and be annoyed that it slipped through my researching! aha.
Any help with making a decision would be very much appreciated, as I have now come to a standstill, and could do with as much advice as possible.
Thanks.
Benq M2700HD
Hanns.G HZ281HPB
.(Extra Question: If the monitor is a 1920 x 1200, then does that mean that as the PS3 can only produce at 1920 x 1080, that the image will be downscaled and result in it looking worse than on a 1920 x 1080 monitor?)
ViewSonic VX2739WM
Asus VE276Q
Thanks.
