Caporegime
- 18 Oct 2002
I'm sure i've done this before, just forgotten how.
Think there is a little app somewhere that can basically do what windows can do for a floppy and format a usb stick and bung on files for booting into dos so i can flash this damn 3870x2 with higher powerplay speeds.
ANyway, i remember the first time i did it with a 2gb usb stick it simply wouldn't work. The app I found would do it for smaller sticks. I just can't remember what that damn program was called.
You'd think in the push to get rid of floppy drives MS would have added the functionality into windows it had for floppys to make them bootable.
I think i might have even done it by finding a floppy image and putting files on the USB stick but again I seem to remember issues there with finding something i could open and extract the files from.
