Making a watertight perspex box
31 Jul 2004
Surrey
I want to make a custom res for a watercooling setup I'm building.
Now obviously perspex is easy enough to come by and cut but what would anyone recommend to stick the pieces together to ensure a longlasting watertight seal?
Also, what bits would I need for my dremel to buff up the edges to make them look as good as a normal bayres? (this isn't going in a drive bay btw, thats just a reference point)
Some of that bathroom filler stuff, dries like rubber.. they use it around windows aswell dont they? If that stops water coming in under the window, i guess you can use it for the same thing
you mean silicone?
Its quite rubbery so I don't think it would hold the box in shape and also it tends to have a colour. I want clear so I can shine lights down the wals.
perspex cube thingies? never had a perspex case so I'm not familiar..
also that stuff you pointed to concerns me with "Forms a permanently flexible rubber seal"
I was thinking more along the lines of a contact adhesive??
You need to use wedge pieces for added strenth, don't use a dremel to get a smooth/shiny edge, use wet % dry paper and elbow grease. Silicon sealent won't glue the pieces together, a hot glue gun will work.
Tensol 70 is what you should be looking for to stick the perspex together, its a two part catalyst cement which cures at ambient temperatures to produce high strength structural bonds.
Do not confuse it with Tensol 12 which is single component cement which produces a non-structural bond.
(and all that from a girl lol)
I have some Zpoxy Quick Set made by Pacer that is a clear 2 part Epoxy Waterproof resin, was recomended it at a Model makers shop, its used to make model boats so should be just the ticket!
