Making DVD backups
9 Jan 2003
Darlington
I'm wanting to turn my collection into a format that I can stream over my network (from PC to PS3 to TV). I've read around a bit and read threads on here and found that most people recommend to use makemkv.
However the first one I tried (a disney film for the kids) obviously has some form of copyright as the video was covered in green lines throughout and was unwatchable.
Am I doing something wrong, or can you just not rip films with copy protection?
Sounds like a likely cause :D
LOL, absolutely!
I ripped the film yesterday with handbrake, not makemkv. Just tried makemkv and it worked a treat :)
So handbrake can't rip copy protected DVDs then I guess. What do I use handbrake for? Sorry for the 'noobness' of this post! :o
If you want to shrink (compress) the rip to save space, then Handbrake is your tool. Also use it for some file conversion duties. The compression is lossy though. A quick couple of test runs will help you work out whether compression is for you and how far you can go.
I've never had an issue with Handbrake to rip DVDs. But assuming you have the space you're better off archiving them without re-encoding them, and maintaining the special features and extra audio channels etc.
