making HTPC out of old parts
30 Nov 2010
UK
*EDIT* I should have put this in General Hardware, could a mod please move it?
I am thinking of swapping my current HP Microserver that I use just for xbmc for something else so I can have more drives. I was thinking about using some old parts but not sure if they would be powerful enough to run 1080p/5.1 surround .mkv files on XBMC, I am sure these would be more then powerful enough but just want to check.
Parts (was originally a ocuk system I bought in 2007):
Asus P5N32-E SLI Motherboard
Intel E6600
8800GTS 512mb
4GB of RAM can't remember speed
Creative Soundblaster fatality platinum
Would also need a cheap htpc looking case that would hold at least 6x 3.5 drives plus a optical drive and a cheap but safe PSU, any ideas?
The 8800GTS could play back 1080p content fine, but you may run into problems with sound.
Does it have a HDMI port? CPU/RAM absolutely fine.
PSU I am a fan of: Corsair Builder Series CX 430w Modular
Safe and modular so there aren't a tonne of unused cables.
Cases, you will stuggle to find a cheap htpc looking case that will hold 6 drives + an optical drive. You may be better off with an matx case instead.
Is your surround controlled by an AV Receiver with HDMI?
You could sell the 8800TGS and pick up a cheap graphics card with HDMI like the (AMD) HD6450 / (nVidia) GT610. You can also get passive versions of those cards so it will bring the noise down quite a bit.
I just have a panasonic surround sound that has optical, phono inputs and outputs. I have a 6450 in my microserver at the moment I can just use that again then.
