Making iPod Touch 2G Mass Storage Device?
3 Jan 2006
Bishopsworth, Bristol
As per title,
I can't see a option to do so..
I want it so I can whack files on there like a USB Memory Stick..
TIA,
Bloomerz
it can't be done as the software on the iPod Touch/iPhone is very different to the older models.
While the older iPods could be formatted as FAT32, the Touch/iPhone run slimmed down versions of OS X and thus need to be formatted as HFS+ which isn't recognised by Windows
So if you plug it into a USB port, it doesn't appear as a removable drive?
I've got an iPod Touch 2G on order for Xmas so would I be best off picking up a cheap memory stick as well?
I've been using IphoneBrowser & just putting files into the media part of my iphone seems to work fine but every comp you use has to have it installed.
