Hi
I've decided I'd like to find out if I can get better locks on my doors.
I have the standard double glazed white doors all round, the ones where you have to pull the handle up to lock them.
Now these are fine, but they are VERY easy to break into, despite the fact that it locks all around the door when you lock it.
To break in with force I'd imagine would be very difficult, but picking the locks is surprisingly easy. (takes me 1-2 minutes with 2 hair clips and a flat headed screw driver)
Also you don't even have to pick them cause they are easily bumpable. Any key that fits in the lock can bump them. I tried the key from my mums house and it bumped on the 2nd attempt.
Are there unbumpable locks? I've never found any, but I'm sure they must have got round this issue by now.
Cheers,
G
Cheers,
G
