Making the Switch...
27 Jun 2006
Well, I've come to the conclusion tonight that my MacBook Pro is going to be my main computer from now on.
I'd been saving wildly for a new PC, but to be honest, I'm going to spend too much money on it. And 2 months (if I'm lucky) down the line it's going to be out of date. And I'll want to update it again. Something of an addiction. A bad one. :D
So, I have a few things I need to clear up before I finally do go and put the nails in the decision - and I'm hoping the brains of your fine selves can help me out.
I've identified a few potential things but if you think there may be more or wish to warn me of any, feel free.
1) My MBP has an X1600 (128mb) - am I likely to encounter any problems with going external on a 1920x1200 monitor? (24" Inch, looking at the Dell HC 2407, specifically)
2) Any potential issues with the USBs/Card Reader on the monitor or pretty straight forward?
3) I prefer to have a clean install of OS X with the 'important' stuff' based on external hard drives. Am I likely to face any perfomance issues?
4) I currently have my SATA-II hard drives from my PC. I had planned to install these into my new rig (as they contain important stuff) - but will it be as easy as buying a hard drive USB caddy and taking the information off them from within OS X? I understand OS X can read NTFS, just not write to it.
Think that's about it for now (unless you can make the new Apple keyboard come into stock :( ) . A lot of the things are common questions which I have looked into online - but would prefer a second, third or fourth opinion on them.
Thanks very much. :)
Another option is to go for the firewire 800 - that gives better performance for attached HDs from what I've read.
Might be a good idea actually, what with how many USB ports I'm planning to use. :)
The Dell has 4 (I think) built into the monitor, so if they worked fine I would be alright for the other bits and pieces.
