- 30 Dec 2007
Hello
I have looked at bootdisk.com and and other sites, they all tell for XP you need three files;
boot.ini, ntldr, ntdetect
Trouble is I can find both nt... files, call up boot.ini in run and save it as a notepad file on the USB stick as well.
Now when I try and restart PC, nothing happens, it just boots up as normal, if I force it to boot from USB, it says PC errror and then boots from hard disk.
what am i doing wrong?
krishan
krishan
