Making your own 120gb 360 harddrive
9 Jan 2005
Stoke-On-Trent
I hear if you buy a WD Scorpio 120GB Hard Drive and flash it can be put in the Xbox 360 20 harddrive enclosure. Anyone done this? I've been trying to find out if you could put a larger harddrive in there like a 320gb but I've found no info on such.
I was thinking of buying the 120 offcial 360 drive but man it's a rip off I could get a TB harddrive for my PC for that money.
AFAIK no you can only use a 120Gb
Also, i think its not really worth doing; you need an original xbox360 120Gb drive to dump the the bin file on the WD drive, if both drives are on Live at the same time you will be banned.
