Malwarebytes for Vista64..
19 Oct 2002
Swindoniantown
Looking on the Malwarebytes website it says Vist (32bit only) in the software requirements..
I have Vista64bit on my Laptop.. is there a 64bit version, or something similar/comparable to Malwarebytes for my system??...
or has anybody got the 32bit version working with no problems on Vista64??.. would this be recommended??..
FYI.. I've got Adaware (newest version) and SBS&D currently along with Avast Professional. :)
Cheers
Sim.
the latest version of Malwarebytes does appear to partially work with Vista64bit. the scanner and removal of nasties works, but the protect doesnt, whenever I try and start the protection it crashs.
i use it on vista 64,i just use it when i want to sweep my pc...it is still worth having for this only even if the real time protection dont work:)
there fully aware of it and are working on a vista 64 fix....
so only the auto protect wont work/ Really wish MS just made one Vista copy 64bit Vista :)
As the above posters have said the real time protection doesn’t work under Vista x64, but malware bytes is still worth installing as its removal and detection is one of the best.
Super Antispyware Pro has real time protection that does work under Vista x64 and is another great Antispyware app well worth considering; The free version has no real time protection and is on demand only. run this app along with Malware bytes and you should be able to remove and detect most malware/spyware crap etc.
