Malwarebytes going berserk?
8 Apr 2010
Since yesterday every 5 minutes or so i get the Anti malware popup saying that access to a possible harmfull website is succesfully blocked and the logbook show something like this
21:21:10 Gebruiker IP-BLOCK 62.45.7.42 (Type: outgoing, Port: 63028, Process: svchost.exe)
21:21:10 Gebruiker IP-BLOCK 62.45.7.42 (Type: incoming, Port: 63028, Process: svchost.exe)
21:21:18 Gebruiker IP-BLOCK 62.45.7.42 (Type: incoming, Port: 63028, Process: svchost.exe)
21:21:18 Gebruiker IP-BLOCK 62.45.7.42 (Type: outgoing, Port: 63028, Process: svchost.exe)
Should i worry?
62.45.7.42 resolves to
"042-007-045-062.dynamic.caiway.nl"
Top Level Domain: "caiway.nl"
Country IP Address: NETHERLANDS
port 63028 I have no idea what it's going for, i'll fire a quick scan at 62.45.7.42.
Toss up a hijackthis log, better safe than sorry
[edit]
Whatever it's trying to connect back to it's running a http server on http://62.45.7.42:10243, tha machine itself is running win7 or server2008
Did a Malware scan, and a Microsoft Essentials scan and nothing came up?Anyways here's the HijackThis log
Running processes:
C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files (x86)\NEC Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe
C:\Program Files (x86)\OpenOffice.org 3\program\soffice.exe
C:\Program Files (x86)\OpenOffice.org 3\program\soffice.bin
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
E:\ITunes\iTunesHelper.exe
C:\Program Files (x86)\Logitech\G930\G930.exe
C:\Program Files (x86)\Canon\Solution Menu EX\CNSEMAIN.EXE
C:\Program Files (x86)\DivX\DivX Update\DivXUpdate.exe
E:\Malwarebytes' Anti-Malware\mbamgui.exe
E:\Last.fm\LastFM.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil10r_ActiveX.exe
C:\Program Files (x86)\Internet Explorer\iexplore.exe
C:\Program Files (x86)\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.be/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe,
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Increase performance and video formats for your HTML5 <video> - {326E768D-4182-46FD-9C16-1449A49795F4} - E:\DivX\DivX Plus Web Player\npdivx32.dll
O2 - BHO: Canon Easy-WebPrint EX BHO - {3785D0AD-BFFF-47F6-BF5B-A587C162FED9} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexbho.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: Use the DivX Plus Web Player to watch web videos with less interruptions and smoother playback on supported sites - {593DDEC6-7468-4cdd-90E1-42DADAA222E9} - E:\DivX\DivX Plus Web Player\npdivx32.dll
O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
O2 - BHO: Aanmeldhulp voor Windows Live ID - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: SkypeIEPluginBHO - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O2 - BHO: FlashGetBHO - {b070d3e3-fec0-47d9-8e8a-99d4eeb3d3b0} - C:\Users\Gebruiker\AppData\Roaming\FlashGetBHO\FlashGetBHO3.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O3 - Toolbar: (no name) - {E0E899AB-F487-11D5-8D29-0050BA6940E3} - (no file)
O3 - Toolbar: Canon Easy-WebPrint EX - {759D9886-0C6F-4498-BAB6-4A5F47C6C72F} - C:\Program Files (x86)\Canon\Easy-WebPrint EX\ewpexhlp.dll
O4 - HKLM\..\Run: [JMB36X IDE Setup] C:\Windows\RaidTool\xInsIDE.exe
O4 - HKLM\..\Run: [NUSB3MON] "C:\Program Files (x86)\NEC Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe"
O4 - HKLM\..\Run: [SwitchBoard] C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O4 - HKLM\..\Run: [AdobeCS5ServiceManager] "C:\Program Files (x86)\Common Files\Adobe\CS5ServiceManager\CS5ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [ATICustomerCare] "C:\Program Files (x86)\ATI\ATICustomerCare\ATICustomerCare.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "E:\ITunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [Logitech G930] C:\Program Files (x86)\Logitech\G930\G930.exe
O4 - HKLM\..\Run: [CanonSolutionMenuEx] C:\Program Files (x86)\Canon\Solution Menu EX\CNSEMAIN.EXE /logon
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files (x86)\Winamp\winampa.exe"
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
O4 - HKLM\..\Run: [DivXUpdate] "C:\Program Files (x86)\DivX\DivX Update\DivXUpdate.exe" /CHECKNOW
O4 - HKLM\..\Run: [Malwarebytes' Anti-Malware] "E:\Malwarebytes' Anti-Malware\mbamgui.exe" /starttray
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [Pando Media Booster] C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
O4 - HKCU\..\Run: [igndlm.exe] C:\Program Files (x86)\Download Manager\DLM.exe /windowsstart /startifwork
O4 - HKCU\..\Run: [AutoStartNPSAgent] C:\Program Files (x86)\Samsung\Samsung New PC Studio\NPSAgent.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O4 - Startup: Iomega Product Registration.lnk = C:\Program Files (x86)\Iomega\Registration\Register.exe
O4 - Startup: Logitech blank Productregistratie.lnk = C:\Program Files (x86)\Logitech\G930\eReg.exe
O4 - Startup: OpenOffice.org 3.2 .lnk = C:\Program Files (x86)\OpenOffice.org 3\program\quickstart.exe
O4 - Startup: OpenOffice.org 3.3 .lnk = C:\Program Files (x86)\OpenOffice.org 3\program\quickstart.exe
O8 - Extra context menu item: &Download All with FlashGet - E:\FlashGet\jc_all.htm
O8 - Extra context menu item: &Download with FlashGet - E:\FlashGet\jc_link.htm
O8 - Extra context menu item: Download all by FlashGet3 - C:\Users\Gebruiker\AppData\Roaming\FlashGetBHO\GetAllUrl.htm
O8 - Extra context menu item: Download by FlashGet3 - C:\Users\Gebruiker\AppData\Roaming\FlashGetBHO\GetUrl.htm
O9 - Extra button: Skype Plug-In - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O9 - Extra 'Tools' menuitem: Skype Plug-In - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O10 - Unknown file in Winsock LSP: c:\program files (x86)\common files\microsoft shared\windows live\wlidnsp.dll
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O15 - Trusted Zone: *.clonewarsadventures.com
O15 - Trusted Zone: *.freerealms.com
O15 - Trusted Zone: http://software.kuaiche.com
O15 - Trusted Zone: *.soe.com
O15 - Trusted Zone: *.sony.com
O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} (CDownloadCtrl Object) - http://www.fileplanet.com/fpdlmgr/cabs/FPDC_2.3.10.115.cab
O16 - DPF: {814EA0DA-E0D9-4AA4-833C-A1A6D38E79E9} (DASWebDownload Class) - http://das.microsoft.com/activate/cab/x86/i486/NTANSI/retail/DASAct.cab
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O16 - DPF: {E6F480FC-BD44-4CBA-B74A-89AF7842937D} (SysInfo Class) - http://content.systemrequirementslab.com.s3.amazonaws.com/global/bin/srldetect_cyri_4.4.21.0.cab
O18 - Protocol: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: AMD External Events Utility - Unknown owner - C:\Windows\system32\atiesrxx.exe (file missing)
O23 - Service: Mobiel Apple apparaat (Apple Mobile Device) - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: ASP.NET-statusservice (aspnet_state) - Unknown owner - C:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe (file missing)
O23 - Service: Bonjour-service (Bonjour Service) - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: Dragon Age: Origins - Content Updater (DAUpdaterSvc) - BioWare - e:\steam\steamapps\common\dragon age ultimate edition\bin_ship\DAUpdaterSvc.Service.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: Canon Inkjet Printer/Scanner/Fax Extended Survey Program (IJPLMSVC) - Unknown owner - C:\Program Files (x86)\Canon\IJPLM\IJPLMSVC.EXE
O23 - Service: iPod-service (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: JMB36X - Unknown owner - C:\Windows\SysWOW64\XSrvSetup.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: MBAMService - Malwarebytes Corporation - E:\Malwarebytes' Anti-Malware\mbamservice.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: SDLService - Unknown owner - C:\Program Files (x86)\Realtek\Smart Dual Lan\SDLService.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: SwitchBoard - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
Deleted the first 3 so called "Trusted zones", restarted pc and untill now no warnings anymore. Anymore things i need to look out for?
I've had a quick scan and I cant see anything obvious there that could be causing a problem (i've had a few though so I may be skirting over something).
Are you from NL?
