Managed switch for home
2 Aug 2005
Hi All,
Looking at getting a half decent managed switch for home, with the view of getting CAT6 run throughout the house. Initially looking at a 24p one if possible, but must be fanless, can't have the noise unfortunately.
Anything around the £100-150 mark would be ideal, am I looking towards something like a DLink?
Open to suggestions
N.B. Thought this would be best suited to the enterprise solutions forums with the discussion around managed switches
Netgear GS724T is a pretty good start. It's L2+ (aka Smart) rather than full L3 but that will probably be enough to begin with.
I use a DGS-1210-24, it does everything I need which is mainly VLAN support. Had it over a year now and no issues. You can get for around £120 at the moment.
Gotta second the Proliant 1810-24. Bullet proof reliability. I've purchased both of mine, used, for under £70 and they've been rock solid since the day I installed them in the rack and set them up
The 1810s are fine for home. I have a few that have been replaced by HP and still have reliability issues though, so hold off on using them for anything critical.
Am going to have a look around for an 1810-24 however those on the Bay seems to be upwards of £100. Looking at completed listings they should be going for much less than that - I will keep my eyes and ears open
Cheers all
I have a 1810-24G and have had it for the last 3 years. Where I am they come with next business day lifetime replacement warranty. My original unit failed, we did get hit by lightning... twice, and I contacted HP via their website and had a replcement delivered the following day. Would have to check if the same NBD lifetime warranty is also standard for this switch in the UK. I almost never reboot the switch and it just keeps ticking along. There is also a 8 and 48 port version and the 1910-24G is also good if you want L3 routing but is a chunk more expensive.
The v2 is a little more efficent, has a little more backbone bandwidth and is in a slightly different format (sits in the center of longer rack ears).
RB
Certainly vlanning & teaming. I have a media server which could do with a bit of throughput, as could my ESXi box. Its main use will be to pass traffic of course form the room.
Getting a managed switch over something like a smart switch or unmanaged is an opportunity to learn a bit too
I picked up a couple of 3Com's 24port Gigabit switches a few years ago dirt cheap on the bay (like £25 each) One's just a smart switch but it handles VLAN's, Teaming, SNMP fine. The other one is a beastly 2U Layer3 proper managed one that would have cost a few grand new. I did have to mod the fans in it for sanity's sake (24V 50mm fans are not pleasant, even with the switch hidden away in a cupboard!)
To be honest a smart switch is fine for all practical home purposes, for learning I'd grab GNS3 where you can go wild with advanced setups.
This. Except VLAN routing. But you could do that in software with pfSense etc.
What I've done is go with a 48 port Netgear 'smart' L2+ switch and a Cisco 10 port L3 switch to handle VLAN routing, with a 4 port LAG between the two. Best of both worlds IMO.
