Hi all
Possibly a stupid question however...
I am wanting to separate my networking set up using VLANS. For example main trunk, IoT, CCTV, guests etc would all be separate VLANS.
My set up:
Router: Ubiquity Unifi Dream Machine (UDM)
Switch: TP-Link TL-SG108S (non-managed)
Using just the UDM I can allocate VLANs to my ports. However, when using the TP-Link to extend connectivity, I loose this functionality as I plug additional devices such as my desktop into the same switch, which needs to be on its own VLAN - Which makes sense as this is a 'dumb' switch.
My question is, if I purchase a Managed switch such as the UnifiSwitch 8 60W for PoE (will be running Unifi APs) to regain the logical routing capability and run the VLANs, can I also use my TP-Link in the mix and still retain the VLAN separation - OR - Do I need to use another Managed switch?
My set up:
