I'm running a duel monitor setup on my 1070, primary through DP and secondary through DVI. The issue it when I turn the monitors off (I often leave the PC on while it's processing renders etc.), the primary monitor (DP) become 'undetected' and everything moves to the secondary monitor.
Trying to research the issue I found this post which is pretty much the same problem. One of the replies looked promising - managing the EDID files for the monitor:
I went to the NVIDIA control panel but the 'workstation' section is missing:
Any ideas how I can do this on my 1070?
Another solution for NVIDIA cards is detailed in DisplayPort Blanking / Screen Autodetect Problems by setting the monitor to use EDID information from a file instead of from the monitor, so auto-detect is not required.
This is done in NVIDIA Control Panel -> Workstation -> View system topology -> EDID source (for the monitor) -> Monitor... -> Export EDID.
