[MANDATORY BATTERY SAFETY CHECK ] Spectral:ON CF/CFR & Torque:ON CF
Caporegime
22 Nov 2005
  • The issue only affects the battery supplied with the Spectral:ON CF / CFR and Torque:ON CF with the model number: BT0001, BT0002, BT0003 and BT0004.
    No other Canyon models are affected including the Spectral:ONfly.
Understanding the issue​
The batteries used for our E-bikes are sourced from reputable companies and tested to meet or exceed industry standards. We have been notified that a small number of batteries may be liable to damage the housing appearing as small cracks, gaps or similar.
In rare circumstances, this could allow moisture inside the battery, potentially triggering a short-circuit that bypasses the fail-safe protection mechanisms. Whilst extremely unlikely, we cannot rule out that a damaged battery might catch on fire, resulting in a risk of personal injury or damage to property.
We must instruct you to please stop using any of the affected batteries in your bike and to not charge them.
You need to remove the battery from the bike and visually inspect the housing for any potential damages as outlined below.
We appreciate your understanding and patience as we work on a solution. We will contact you at the beginning of December with an update.
:eek:
Anyone got one?
