Mandriva Xorg.conf -> Ubuntu Xorg.conf
24 Jun 2007
Landan.
Afternoon all,
I've got an old laptop that uses an obscure VIA chipset for its graphics, as such it's an absolute PITA to get working and I've never (ever) been able to get it working in Ubuntu.
However, I can get it to work perfectly in Mandriva. So I've got the xorg.conf from the Mandriva install, and I've ported it over to a fresh Ubuntu-Netbook 10.10 install - but it's not liking it (X loads fine, can login, but then all sort of weirdness cracks off). I've checked and the latest openchrome drivers are already installed, and also I had to install v4l as it wasn't already installed - but still no joy.
Can anyone spot anything from the xorg.conf below that Ubuntu wouldn't like?
Code:
# File generated by XFdrake (rev )
Section "Extensions"
    Option "Composite" "Disable"
EndSection
# Refer to the xorg.conf man page for details about the format of
# this file.
Section "ServerFlags"
    Option "DontZap" "False" # disable <Ctrl><Alt><BS> (server abort)
    #DontZoom # disable <Ctrl><Alt><KP_+>/<KP_-> (resolution switching)
    AllowMouseOpenFail # allows the server to start up even if the mouse does not work
EndSection
Section "Module"
    Load "v4l" # Video for Linux
EndSection
Section "Monitor"
    Identifier "monitor1"
    VendorName "Generic"
    ModelName "Flat Panel 1280x800"
    HorizSync 31.5-50.0
    VertRefresh 56.0-65.0
    # TV fullscreen mode or DVD fullscreen output.
    # 768x576 @ 79 Hz, 50 kHz hsync
    ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
    # 768x576 @ 100 Hz, 61.6 kHz hsync
    ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
EndSection
Section "Device"
    Identifier "device1"
    BoardName "VESA driver (generic)"
    Driver "openchrome"
    Option "DPMS"
EndSection
Section "Screen"
    Identifier "screen1"
    Device "device1"
    Monitor "monitor1"
EndSection
Section "ServerLayout"
    Identifier "layout1"
    Screen "screen1"
EndSection
One thing that springs to mind is the name of the devices. If I remember rightly in Ubuntu the LCD panel is called default, so I'm just about to try changing that and will report back.
Cheers.
EndSection
Try changing it to "Enable". I know Ubuntu likes to use all the fancy compositing stuff so that may be causing a problem. It's strange that its fine for the login but not for your desktop, which is what is making me think it's trying to start some fancy graphical programs and bailing. Another option is to try and turn all compositing off (compiz etc...).
Part of the reason you're having problems is more than likely because Mandriva have decided to apply some custom patches &/ or are using a different revision of the openchrome drive to Ubuntu. Unfortunately, this is one of the problems with the different Linux distros.
First question-
If you change the driver for device to VESA, does it work? (Obviously, this may not give all the visual effects, but it should work on pretty much anything)
Second question-
What do you mean by wierdness? Is xorg dying and dropping you to the terminal, are you getting graphical corruption or what?
If you can get to a console, the last 30 lines or so of your dmesg may give us a better idea of what's going on. My first instincts are a bug in Ubuntu's implementation/ compile of openchrome though :)
-Leezer-
Cheers for the replies guys, I've been battling with this over the past couple of nights.
VESA does work, but only at 800x600 as you'd expect. If I use the OpenChrome driver, and run startx as root (after first booting into text mode) - X loads, and looks pixel perfect, but it's using 1600x1200 resolution.
If I let it boot normally, into the 'netbook' form of the GUI, all hell breaks loose - the resolution is still at 1600x1200, but with the added thing of the screen being garbled/graphical corruption etc. It's unusable in that state.
Here's the output from a fair few of the graphical commands:
Code:
root@eros:~# xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 800 x 600, maximum 800 x 600
default connected 800x600+0+0 0mm x 0mm
   800x600        61.0*
   720x576         0.0
   720x540         0.0
   720x480         0.0
   640x480        60.0
Section "Device"
        Identifier "Default Device"
        Driver "vesa"
EndSection
Section "Monitor"
        Identifier "Default Monitor"
        HorizSync 31.5-50.0
        Option "Preferred Mode" "1280x800_60.00"
        Modeline "1280x800_60.00"   83.50  1280 1352 1480 1680  800 803 809 831$
EndSection
root@eros:~# get-edid
get-edid: get-edid version 2.0.0
	Performing real mode VBE call
	Interrupt 0x10 ax=0x4f00 bx=0x0 cx=0x0
	Function supported
	Call successful
	VBE version 300
	VBE string at 0xc698d "VIA P4N800 PRO
VBE/DDC service about to be called
	Report DDC capabilities
	Interrupt 0x10 ax=0x4f15 bx=0x0 cx=0x0
	Function supported
	Call successful
	Monitor and video card combination does not support DDC1 transfers
	Monitor and video card combination supports DDC2 transfers
	0 seconds per 128 byte EDID block transfer
	Screen is not blanked during DDC transfer
Reading next EDID block
	Read EDID
	Interrupt 0x10 ax=0x4f15 bx=0x1 cx=0x0
	Function supported
	Call failed
The EDID data should not be trusted as the VBE call failed
Error: output block unchanged
root@eros:~# dmesg | grep agp
[   14.424555] Linux agpgart interface v0.103
[   14.649724] agpgart: Detected VIA VT3314 chipset
[   14.840468] agpgart-via 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
I'm just about to attempt compiling the openchrome driver using the script here:
http://ubuntuforums.org/showthread.php?t=485646
I'll report back shortly (or maybe a lot longer depending on how long it takes to compile :p).
Any other tips/suggestions in the meantime please let me know :)
Hmm, sort of a development. At first glance that script didn't work, i.e. it's still using 1600x1200 (and it shouldn't do anyway, 10.10's openchrome should be using that branch I've checked out and compiled). Well anyway, I can now select resolutions which I wasn't able to do before - however, if I choose 1280x800 the screen just completely garbles, I can just about make out stuff on screen, but it's bad enough that I don't want to risk trying to click "Don't use this resolution" :D
Argh - it's retarded that it's this hard to get it working when it works fine in Mandriva.
Also, have they got rid of dpkg-reconfigure xserver-xorg? :confused:
Yep, it's supposed to automagically figure itself out now :rolleyes:
Not sure why VESA is stuck at 800x600, it absolutely shouldn't be. Should run different resolutions just fine, only thing with problems ought to be fancy graphics acceleration.
Have you tried changing the resolution once logged in with VESA? I've got one VESA box which runs permenantly at 1280x1024, and from a quick test on the desktop it supports 1920x1200 just fine as well.
Can I just check whether you've currently got Compositing set to Enable or Disable?
I note in the Mandriva 2010 errata that compositing is broken in their current driver revision. ( [http://wiki.mandriva.com/en/2010.0_..._to_start_with_S3_Unichrome_graphics_chipsets )
Either way, try flipping the option and see what happens.
Final point- Looks like your monitors display data reporting is bugged somewhat. Try defining *everything* (Resolutions refresh rates etc.) in xorg.conf & don't rely on Ubuntu to get it right.
-Leezer-
Cheers for the reply, and thanks very much for taking the time to look at the mandriva docs etc, it's appreciated :)
I've tried with compositing both enabled and disabled, using both the openchrome and vesa drivers, both with the same result as before. Vesa definitely only goes upto 800x600 in the GUI options -X also complains when I login about the 1280x800 resolution in the xorg.conf (i.e. that it can't do it with the vesa driver). I've also tried the vesa driver with the "Option" "DPMS" line removed, but didn't make any difference.
Argh this is so annoying - do you know if there is anyway I can copy the binaries/whatever is necessary from a Mandriva install?
I also gave installing the proprietary VIA drivers a go, but that just FUBAR'ed the lot :p
Proably not, they're running a different Xorg revision. You might get lucky though, so try it and see what happens.
My first port would be trying to use alien to actually install the current Mandriva Openchrome RPM ( x586- http://doc4.mandriva.org/bin/view/d...a4c7cfbf14fd9c2148e9?d=$distribution#overview )
If that doesn't work (Not too hopeful, this is a system level app), a manual copy of files may work. These ought to be the files in question, although you can ignore the /usr/share ones, as all they're doing is giving you the manpages:
Code:
/usr/lib/libchromeXvMC.so
/usr/lib/libchromeXvMC.so.1
/usr/lib/libchromeXvMC.so.1.0.0
/usr/lib/libchromeXvMCPro.so
/usr/lib/libchromeXvMCPro.so.1
/usr/lib/libchromeXvMCPro.so.1.0.0
/usr/lib/xorg/modules/drivers/openchrome_drv.so
/usr/share/bug/xserver-xorg-video-openchrome/script
/usr/share/doc/xserver-xorg-video-openchrome/NEWS.gz
/usr/share/doc/xserver-xorg-video-openchrome/changelog.Debian.gz
/usr/share/doc/xserver-xorg-video-openchrome/changelog.gz
/usr/share/doc/xserver-xorg-video-openchrome/copyright
/usr/share/lintian/overrides/xserver-xorg-video-openchrome
/usr/share/man/man4/openchrome.4.gz
/usr/share/xserver-xorg/pci/openchrome.ids
Final try on this front would be compiling from the Mandriva source, but again I'd make no warranties whatsoever about this working. Their source RPM is here: http://doc4.mandriva.org/bin/view/d...me-0.2.904-2mdv2010.0.src.rpm?d=$distribution
Realistically though, I'd probably be going with Mandriva after trying these, there just seems to be something about Ubuntu that this machine doesn't like :)
IMHO Ubuntu's been going downhill for a while now too, and if it wasn't such a pain I'd have moved away from it.
-Leezer-
