Manipulating a textbox input
25 Jul 2003
London
Hi,
I am trying to send a value that is entered in a text box to some flash memory.
RCFlashIndexAppend(Board,0,50,1,"textBox1");
Will this method of pointing to the textbox work? Or do I have to some how save the input beforehand.
Thanks
Well I have no idea what language and API's you are using so I doubt anyone else does either, that would be some helpful information. Genrally in programming a double quote enclosed piece of text is treated as a String so you are passing in a String which contains "textBox1" and not the contents of the text box. You may not get an error because the method "RCFlashIndexAppend()" is probably expecting a string and your giving it an explicit String, not the contents of the text box.
As I don't know your programming language I can't really advise you but this is what I would do if I was programming in Java:
String contents = textbox1.getText();
someMethod(<params...>, contents);
Thanks for you reply.
Im am using C++. Sorry, should have stated that.
So how would I do that in C++? Any tutorials on this issue?
