Manually adding to WMP11 library
18 Oct 2002
Leamington Spa
Is there any way to manually add songs to the WMP11 library? I can only find options for monitoring folders. I don't want to monitor the folder, I just want to put some files into the library. Actually monitoring a folder would be fine, but it doesn't seem to work.
edit- nevermind it spontaneously started working. Mods can delete this thread if they want.
