- 5 Jun 2007
- extremes.spacious.indelible
Can it be done and if so how?
Just installed and monitor doesnt like the res
it's in a hidden bit in the documents and settings folder. There's an ini file you can editMegahurtz400 said:Can it be done and if so how?
Just installed and monitor doesnt like the res![]()
zytok said:it's in a hidden bit in the documents and settings folder. There's an ini file you can edit
something like that, remember it is pretty hard to find. Somewhere like local settings/application data/atari/rct3Marky said:Yep I remember I had to do this.
It's an ini file found in the documents and settings folder in a folder with the name of your profile, if I remember correctly.
