- 18 May 2010
Hi all
I put my new PC together last night with CAS8 RAM but the motherboard applies CA9
I know I can manually change it but a couple of things confuse me and I was hoping someone could help
Here is what my BIOS displays
CAS# Latency = auto = 9T
RAS to CAS R/W = auto = 9T
Row precharge Time = auto = 9T
Minimum RAS active time = auto = 24T
Here is where I get confused, if you look at memory it often just says CAS8 or CAS9 or whatever it is advertised at, also it often gives a full string of numbers like my memory states
8-8-8-24
Is this basically what I need to manually apply to the BIOS, so that it looks like this? Its confusing because they are not all called CAS
CAS# Latency = auto = 8T
RAS to CAS R/W = auto = 8T
Row precharge Time = auto = 8T
Thanks in advance for any help
8-8-8-24
