- 25 Jun 2006
When trying to install Windows XP Pro onto a fresh-built Shuttle SK22G2, I'm getting lots of messages telling me files cannot be copied and either to skip, retry or abort. How so?
Honestly not sure about that. But you could integrate the drivers using nLite. You'd have to copy the Windows disc over to your PC then run nLite and integrate the drivers before making an ISO file that you then burn to CD/DVD and run.Air Marshal said:I reckon now that it's because I neglected to install the SATA drivers. Problem is, I have no floppy drive.
Would setup see it if I plugged in a USB key with the drivers on?
Sounds like a borked disc to me.Air Marshal said:WinXP install reports that VIA------.sys is corrupted, and I have to abort. Any more ideas?
Air Marshal said:How do I check all this stuff? I don't have an endless supply of components to swap in and out on a whim.
