I'm looking to put together a system for development and testing of a highly threaded library.
I don't need a fancy case or multiple GPUs.
I don't need (and would be bugged by) LEDs that serve no purpose on the motherboard, fans, or elsewhere.
I won't be clocking the cpu (other than to turn it down a touch to extend life, if that is possible).
The machine will be run flat out for long periods, but I won't consider liquid cooling, so a good fan & heatsink ,rated to the cpu's standard thermal rating is important.
DDR4 memory is desirable.
In short: as many threads as possible; as fast as is commensurate with reliability and longevity; for as little money as I can get away with.
I'm thinking Ryzen 7 (but which one is the best balance of oomph and cost?); AM4 motherboard (which brand/model); the Wraith Stealth Cooler sounds like the real thing, (but is it up to extended runs (days) flat out?).
What else do I need? (Power supply rating; gpu (or built-in) graphics for basic HD display; memory; basic sound.) I have terabyte disks and 120GB ssd.
Thanks for your opinions, Buk
