Hi
I created a GPO to map network drives. The steps in it are to delete all drive from I: onwards and then map 5 different shares.
The problem I'm having that the GPO is not applying on logon. If I do a gpupdate /force it will apply but if I then disconnect some of the shares and then log off/on they shared don't map unless I do gpupdate /force again.
What could be causing this? The drives were previously mapped bu a script and this GPO is disabled.
If I do gpresult / r I can see the drive map policy showing in the list of applied GPOs.
