Mapping a Drive
31 Jan 2007
I am trying to map a network drive. The drive i wish to map is an p machine and the pc is called PETERCOMP.
In the Map Network Drive dialog box I click browse and the Netwrok folder tree expands but does not show PETERCOMP. The folder I wish to map as the drive is set to be shared
Any ideas?
Turn off simple file sharing on the host machine and try again. make sure you have permissions for it too on the security tab.
- Pea0n
Do you have an account of the same name / password on both PCs? This is necessary I believe to access other drives if they are on a PC (not necessary if Network Attached Storage)?
when mapping a drive (dialog box with 2 text boxes for path), there's an option to connect via a different username and password
try that
