Mapping Network Drives
16 Jan 2008
Having trouble setting up my server with Sonos. The file structure is as follows:
Store (share folder)
-Personal
--User1
---Music (where ever it may be on their backup)
--User2
At the moment each user's computer backs up to the NAS (Qnap TS-410U), however I want to be able to pull the music from their specific files, as specified, however Sonos only supports network shares, so will connect to store, but not anything below it. Is there a way of tricking it or aggregating the music folders as a share folder.
(Running Windows Server)
Thanks
Can you not just enter the details like this
Server name: NasBox
Share name : store\personal\music
It might work as it probably just uses those variables to create a UNC path within it's config, which if it bolts those two together will drill down to the correct place.
