** March Madness - Corsair A50 CPU Cooler **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The hugely popular A50 from Corsair is now at a all low price offering quality, which is well known with Corsair and performance to boot!
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £21.98 inc VAT
nonl2brExcessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.<br>
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.<br>
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.<br><br>
- Compatible with Intel and AMD systems<br>
- Three 8mm copper direct-contact heatpipes<br>
- Aluminum fins<br>
- Low-noise, low-vibration 120mm fan mounted on rubber studs<br>
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want<br>
- Air flow: 50 - 61 CFM<br>
- Noise level: 26 - 31.5 dBA<br>
- Two-year warranty<br>
Was £26.99 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
I've got a AC Freezer 7 Pro which is kinda noisy on a Pentium D 945. Is this able to dissipate more heat while staying quiet due to its size and big fan?
Yes, its a much better performer, hence why OcUK uses it for much of our System Intergration side of the business.
yea I like it. Good price and would make a nice change from the old AC Freezer... Would have like to go water cooled. maybe a nice deal on a corsair sealed water cooling unit?
