It looks like I am going to spending a lot of time afloat in the near future which is awesome.
The boat will be in a Marina with WiFi - however the hull of the boat is 6mm Steel plate and the deck is 4mm steel plate so I rather doubt I am going to get great WiFi signal in the boat and don't really want to have to sit on the deck every time I want to read the Forum!
It has been a very long time since I have done any networking - the home wifi modem that came free with the internet has been sufficient for me for the last half a dozen years. So I am wondering if a few things are possible...
Case 1. I buy a reasonably expensive outdoor rated WiFi repeater and fix it to the mast. As it will then be repeating straight down it might be able to provide signal inside the boat.
Case 2. If I buy a WiFi repeater and a unidirectional antenna I could put an antenna on the mast and run a coaxial cable down to the repeater. Do all the antenna on a WiFi repeater receive and send? In this instance an antenna inside the hull will be repeating the signal. how much loss will I get from the CoAx - and does this even work?
Case 3. If I get a Motherboard with on board WiFi which has two CoAx inputs can I do the same as Case 2 but get to buy a new Motherboard not a WiFi repeater?
Case 4. I buy a Marine WiFi antenna solution for $$$
Would any of these work or is there a better / different solution that I have not thought of?
