What do you get if you mix a Cosworth engine, Williams KERS unit and Mclaren Applied Technologies into a car? The Marussia MR02
http://www.f1fanatic.co.uk/2012/08/29/marussia-williams-kers-2013/
“Yes we will be using KERS next year,” said Symonds. “We plan to adopt the system that has been developed by Williams, which was used by them with the Cosworth engine last year and is currently with their Renault-engine car.
“Our 2013 unit is a development of this. We’ve been very impressed with the engineering, the efficiency and the weight. Williams are also a pleasure to work with both technically and commercially.”
There will be no change in the team’s choice of engine supplier: “We will continue with the Cosworth engine.”
“We are happy with the work we are doing with them and I think that we are working together to try and improve the areas that we are able to under the regulations. We are concentrating on improving the driveability of the engine and enhancing its performance as a unit with the car.”
The team’s 2013 car is “on schedule”, he added. “As always, it’s a tight schedule, but that’s the way it should be if you want to bring maximum performance to the car.
“There are some reasonably significant changes, but in many ways it’s a progression of the MR01 – the lessons we have learnt from that car, from racing it now for half a season and some of the things that we wanted to do to that car that we simply didn’t have time to do last year. So everything is on schedule and we are looking forward to a productive winter of testing and a strong start to the 2013 season.”
