Mass Effect 1 Texture Issues...
6 Apr 2010
Cambridgeshire
So I thought I would boot up Mass Effect and actually try and play it this time. I setup my game will full graphical settings and 1080p and started a new game. That all went fine. Now in game lots of the textures are broken. For example, in the starting room on that flight deck, all the chairs are just a solid blue colour. When I move about you can see the texture flicking behind the blue but the blue is always on top. Some of the other textures are also doing the same.
Any ideas?
I have tried changing every graphical setting one by one and looking for improvement but everything does it. Helps? :P
Latest 260 drivers for nVidia do this unfortunatly :( should be fixed in next set - for the meantime grab the 258.96 WHQL drivers and all should be good.
EDIT: On another note - don't run fraps - if you use it - with mass effect (1 & 2) as it seems to cause random hard lockups for some reason.
Fantastic dude! I will grab those drivers now.
