MAss Effect Andromeda FPS
12 Mar 2017
West Midlands
Hi Guys,
The recommended specs on this game are though the roof, I was just wandering if anyone had beta access that's done some FPS testing on this game?
You should be able to play the game by reducing some of the options. It's rare that the game developers want to exclude high parts of player base.
How well it is optimized we will have to wait and see.
My rig is described in my signature and I am not worried about playing it at least at medium-high settings.
I know but my graphics card is a little out date I'm running a Gigabyte 460gtx so 1gb which in its day was a good card. My monitor is a little outdated to which I cant decide to between a £365 2k monitor or a £126 1080p monitor.
I reckon you will be lucky to get it to run at all with 1gb vram.
From Origin....
MINIMUM SYSTEM REQUIREMENTS
OS: 64-bit Windows 7, Windows 8.1 and Windows 10
PROCESSOR: Intel Core i5 3570 or AMD FX-6350
MEMORY: 8 GB RAM
VIDEO CARD: NVIDIA GTX 660 2GB, AMD Radeon 7850 2GB
HARD DRIVE: At least 55 GB of free space
DIRECTX: DirectX 11
RECOMMENDED SYSTEM REQUIREMENTS
PROCESSOR: Intel Core i7-4790 or AMD FX-8350
MEMORY: 16 GB RAM
VIDEO CARD: NVIDIA GTX 1060 3GB, AMD RX 480 4GB
DIRECTX: DirectX 11
it shouldn't be to bad my system is;
CPU - I5-7600k 3.8ghz (cm 212x heat sink)
RAM - 16gb 2400Mhz Vengeance
mobo - prime-h270-pro
hdd - SSD Samsung Evo 850
graphics - Gigabyte 460gtx so 1gb
monitor - 900p Samsung rose 19"
I think your right Breadturbo 2gb on-board graphics ram ><
Looks like ill need a new graphics card any recommendations?
Used is probably the way forward atm
Sorry new to forum, what's the mm?
Apologies didn't notice your post count, I believe you need a certain amount (used to be 1000) before having access (It's where forums member sell used gear).
If used is best, then a 970/980/980ti would be the best bet or even a 780 if the budgets tight.
This game looks and plays like gears of war(watched videos)which to me is crap, I used to love gow, but I hate that camera angle of choice, so I won't be joining the ME club, but I'd be interested to see /read how this fairs up on release.
I dont know if it helps , but if you £24 for a year (think it is ) to Origin you get access to quite a few good games e.g Battlefront 4 ,Hardline , Star wars Battlefront and loads more.
Also you get to trial Mass effect Andromeda for 10 days too :)
Just a suggestion:)
Just a suggestion:)
Wouldn't personally recommend origin access unless there's something on there worth while to you, nothing has changed in months, so really it's only good for early access/trials for new games. I already own SWBF and BF4 on disc, the vault was only good for me for titanfall and simcity, tried the others, didn't appeal so currently I don't have it till I decide to carry in my simcity progress, hardline was always laggy, NFS15 is crap in general, that Unravel is quite good, then you go the ME and DA for those fans which I suppose would be a plus to the OP if they don't already have ME of old.
