it wouldve been easier for you to type your title in google and click the first page like i did
Minimum System Requirements for Mass Effect on the PC
Operating System:
Windows XP or Vista
Processor:
2.4+GHZ Intel or 2.0+GHZ AMD
Memory:
1 Gigabyte Ram (XP)
2 Gigabyte Ram (Vista)
Video Card:
NVIDIA GeForce 6 series(6800GT or better)
ATI 1300XT or better (X1550, X1600 Pro and HD2400 are below minimum system requirements)
Hard Drive Space:
12 Gigabytes
Sound Card:
DirectX 9.0c compatible sound card and drivers
Recommended System Requirements for Mass Effect on the PC
Operating System:
Windows XP or Vista
Processor:
2.6+GHZ Intel or 2.4+GHZ AMD
Memory:
2 Gigabyte Ram
Video Card:
NVIDIA GeForce 7900 GTX or higher.
ATI X1800 XL series or higher
Hard Drive Space:
12 Gigabytes
Sound Card:
DirectX 9.0c compatible sound card and drivers – 5.1 sound card recommended
Additional Note from Derek French:
The Mass Effect Config program will automatically adjust your settings on first run, to attempt to give you an optimal play experience. As with all PC games, computer performance varies from system to system and adjustments can be made via the Config or through the in-game options to tailor your experience.
