Mass Effect - Will now work
23 Oct 2009
Derbyshire
Afternoon people,
Installed Mass Effect which I bought from the Steam sale and it just does not want to work with Windows 7. I've tried every possible combination to my knowledge...
- Verifying game through Steam
- Defragging through Steam
- Re-downloading the game
- Running as Admin, both the launcher and .exe in the Steam folder
- Every other combination possible i.e comparability mode/admin right
- Changing the names of some .dll files
Really doing my head in as i'm not back till the 4th so want to start playing now. Already re-downloaded the 15GB game, twice. Looked all over Google and tried all the suggestions, still won't work.
Help please, before I break something!
'Mass Effect has stopped working
Windows can check online for a solution to the problem.
-> Check online for a solution and close the program
-> Close the programe
View problem details'
Problem signature:
Problem Event Name: APPCRASH
Application Name: MassEffect.exe
Application Version: 1.2.20608.0
Application Timestamp: 4a55fea1
Fault Module Name: MassEffect.exe
Fault Module Version: 1.2.20608.0
Fault Module Timestamp: 4a55fea1
Exception Code: c0000005
Exception Offset: 008b752d
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Strange, mine worked just by running as admin, although I have the standalone version.
Did you try checking the "run this program as administrator" on MassEffect.exe and then starting from within Steam as normal?
Some people have had to run Steam in admin mode, then start Mass Effect from there to make it work.
Craig
Christ...
Started fine when I clicked run as admin on the .exe this time but didn't work yesterday...
What in the ****.
Thanks for the help, love it how it decides to work now...
Is there any way to make every bit of software run as administrator by default? I've just started using Windows 7 and this is really starting to get on my ****.
Christ...
What in the ****.
Only way to do that is to switch UAC off, but then you lose that entire section of security. I really wouldn't recommend it.
Craig
