- 10 Nov 2006
- Lincolnshire
Ok this is starting to drive me crazy, 3 months ago I had a perfect 3770k @ 4.8 with 1.350v prime95 stable never going over 85c (other specs 6990 and P8Z77). Completed Crysis3 with this spec.
I recently upgraded to CF7970GHZ and this is where my problems started.
I hit the wall O/Cing the cards at 1175/1700 @1.263v so I’ve backed it down to 1.250v @ 1125/1600 for a nice stable O/C, I’m sure my problem doesn’t lie here.
My Computer is stable in all benchmarks with the above GPU O/C and CPU @4.8, but Crysis 3 makes the system BSOD within 2-5mins of game play.
I re-ran prime95 and my temps are out the roof on what was a nice stable over clock now hitting 96c.
My PSU makes noises on a level I’ve never heard before while playing Crysis and when this happens my GPUs start getting hot quick and so does the CPU.
I’ve re-seated my CPU and applied more thermal paste but hasn’t had much effect.
Now when I take my CPU back to factory settings I can run Crysis3 fine no crashes and my GPU's never hit 80c even with my O/C as above. So unstable O/C on the CPU I thought.
Either my CPU has become very unstable and hot OR my PSU can’t cut it anymore or its had its day (TX750W). It seems strange all this has happened since I have upgraded to CF7970GHZ.
Could resetting the CPU back to stock have saved enough energy for the rest of the system to be stable and the PSU can cope better, or there’s possibly something wrong with my CPU.
As I left the house I had the CPU stable in Crysis 3 and prime95 at 4.6 @ 1.30v. I Started prime95 and the temps started high but the PSU was still spinning loud, the PSU shut up the temps seemed to come down nicely too.
Its either a CPU or PSU problem Im sure, as I said all ok in other benchmarks and memtest86 solid. Here is the guide I used to O/Cing my CPU and the settings I have in my bios.
http://www.overclock.net/t/1291703/ivy-bridge-overclocking-guide-asus-motherboards
Much need your advice please, on the verge of buying another PSU here but dont want to waste my money.
