Master/slave "energy saving" power strip
9 Mar 2010
Why is this so hard to find these days?
I've got a bunch of equipment that I want to turn off when my computer is shut down. Access to sockets is pain so I want another "energy saving" extension lead that I've used in the past (https://www.amazon.co.uk/dp/B003WK62WU/ref=cm_sw_r_apan_glt_fabc_4QRPFN2DP48VKZFAS3JJ) but seems to be out of stock everywhere.
Currently turning everything off manually so looking to automate that, not just a power strip with switches.
Anyone got any recommendations?
I would imagine they're phasing out in favour of smart power strips. I've got a 4gang which you can control individually, or switch the whole thing off.
Doesn't the equipment have a power button on them?
Or do you mean that's what you're doing already?
That's what I'm doing at the moment but some of it is cupboards but the most annoying bit is a monitor that when it stops receiving signal wont come out of standby again. Needs to be power cycled at the wall :rolleyes:
Yeah, I've seen those but they don't really solve my problem. Unless they're smart enough that I can add routines based off whether one of the sockets is drawing power...?
I use a couple of 'OneClick' power strips for exactly this.
One socket is master (PC plugged in), others switch on/off based on the master socket.
So Monitor, printer, Powered USB hub, DAC, Power amp all are hard OFF with the pc. No parasitic loads.
I also use one with my hifi in the living room, so when dac (which acts as a preamp) is off the sub, brace of class D amps and streamer all power off too.
Reduces parasitic loads, saves me having to remember to switch things on/off and saves training the other half/boy in switching things on and off.
https://www.amazon.co.uk/ELECTRIUM-Oneclick-Intelligent-Mains-Panel/dp/B0007SQK54
I had one of these for years that I got free from npower unfortunately as my pc’s power draw declined over the years it reached a point where it didn’t draw enough when using desktop apps to trigger all the other sockets to come on!
just ordered one, hoping its decent as ive had a few of these type of product decide to play up after awhile :( odd that they have seemingly been discontinued as a thing...
just a quick question to folk that have them . do you have to physically switch the main item off or is it standby.
reason i have 3 monitors and a printer linked to the computer and at the moment have them on remote switches , problem is sometimes when i switch the power off on the computer it forgets the monitors and i have to manually power them off and on with there own switches?.
so i guess what im asking is will the monitor powers turn off and the computer goes to standby.
sorry to be confusing...
The main item will remain powered, the other plugs get switched off.
So for my computer, I do shutdown via windows and it goes into standby. That’s a low enough draw that it switches the other plugs off so all my monitors and accessories get “turned off at the wall”.
I had the same problem as you where I had to turn off my monitors at the wall every so often, so sounds like it might solve your problem too.
