Master Socket extension?
27 Jan 2005
S. Yorks
Had fibre installed a while ago, the engineer spoke to my wife and they decided between themselves not to run it upstairs to my office but leave it downstairs.
Anyway wife is now fed up of there being two boxes downstairs at the side of the front door and wants it relocated upstairs, what do I need to buy to move the modem and router upstairs out of the way? how difficult is it to run the cables down the walls in the house, house is approx 15 years old?
regards,
Matt
You should only need to run the small/thin RJ11 cable up the wall from the master socket to the modem, luckily they're really small thin cables so can be hidden quite well. You may need to purchase a longer one (I picked up a 25m one off of eBay) and then some very small trunking from Screwfix
watch this video
he does waffle on but it shows the basics of what connections to connect to where.
