Mastercase H500M fan setup
27 Sep 2013
Hi, Im looking at getting a H500M mesh
Im thinking of adding 2 200mm RGB fans on top of the case under these will sit my 240mm aio radiator. from looking at the specs I wont be able to fit my current 120mm fans in a push configuration (43mm clearance) and the 200mm acting as the pull. I also have a gpu aio cooler which will hopefully fit somewhere either as exhaust or behind the front panel 70mm clearance here so it will fit there.
Will the 200mm ontop be enough to cool the radiator without push fans? will the push fans fit? is this the wrong case for the job?
Looking at reviews etc i think 3 140mm fans in the top with the radiator below is the way to go maybe with the current fans as push and new rgb fans as pull!
