so i just swapped my pc in to a new case and i went from an air cooling to watercooling and when i ran prime 95 i found [my cpu temps would hit 100 in 7 mins and the pc shut down so i cleaned off the paste and instead of spreading the paste this time i put a dot in the centre and i ran the test again and i hit 100 degrees in seconds. im running an i7 6700k at stock speeds is my water cooler DOA or is it my pasting abilitys? everything was fine untill i swapped to the water cooling
